Dicrepancy between compiled projects in Quartus II Prime
- 3 years ago
Well if that indeed is your top level schematic, you have wired channels A...H and the trigger all to the same 16b bus.
So it is not surprising at all that logic is eliminated.
When compiled as a top module, all inputs and outputs are assumed to be used by Quartus, and the logic is generated.
Once instantiated as a sub module, Quartus can detect unused logic paths, and remove them.
Probably what you are seeing happen.
- HugoStein3 years ago
Oh, I see.
At first, I thought there was some misconnection in the system, but my knowledge of quartus with block diagram is limited, so I didn't find a proper way of checking. Given that I'm using symbols in the block diagram with Verilog code as shown in the images below, do you have any suggestions?
Thank you so much for the reply,
Hugo Stein
