8 years agoDiagnostic failed for DE5a_Net_DDR4 Arria 10 FPGA
Hi, I am using DE5-net board from Terasic on windows 7. I just followed the Intel FPGA SDK for OpenCL Getting Started Guide and the DE5a-Net OpenCL User Manual by Terasic. And now I have a prob...
HRZ
7 years agoIf you are talking about the PCI-E driver for using OpenCL on that board, Terasic only officially supports RHEL/CentOS; if the PCI-E driver doesn't work on Ubuntu as it is, there is little that can be done unless you are willing to manually modify the driver to make it compatible with the kernel used on Ubuntu. Even then, there is no guarantee the board will work correctly.
