11 years agoHi Victor,
I've got the same problem "internal compiler error" and the error in the .log file is: Error (293007): Current module quartus_map ended unexpectedly. I'm using de5net_a7 too. Did you happen to figure out the fix for this? Thanks -Peter --- Quote Start --- Hi gigi, I appreciate your interest in helping me diagnose the problem. Unfortunately after I upgraded the Altera OpenCL SDK, I recompiled, resulting in the .log file to be overwritten. As far as I can remember, there were no hits when I ran a string search of "error" in the .log file. There were two warnings that I can't remember off the top of my head, but that was about it. So the "internal compiler error" message kept me baffled for a while. The target board was a de5net_a7, from Terasic with the Terasic BSP for Altera OpenCL SDK version 14.0. I have been unable to replicate the problem after the update to Altera OpenCL SDK Service Pack 2, even with the exact same .cl code. Kind regards, Victor --- Quote End ---
