17 years agotwo quick questions...
1)...During compliation, Quartus II decided that some FSM state bit will be used as clock signals...How can I avoide these situations? These errors generally look like this: Warning: Node: EC_DeFramer:inst3|SC.state_bit_0 was determined to be a clock but was found without an associated clock assignment. 2)..I just added "set_clock_groups -asynchronous -group {80MHz 40MHz} -group {2p667MHz_CCTCLK} -group {2p667MHz_CCRCLK}" to the design with the PLL..and now the setup/hold timing isses are gone? Are they really gone or they are just masked out? --- Quote Start --- When sending data between asynch clock domains, two things can happen: 1) The data can be changing just as the receiving register clocks it, causing the register to go metastable. Doesn't happen too often, but the metastable output can trickly down and cause failures elsewhere. 2) When sending more than one bit that are analyzed together, they will all arrive at slightly different times. So if the receiving registers are at "0000" and you send "1111", that transition may occur around a clock edge, so some registers clock in the 1s and the others don't. Your data is no longer valid. Understnading clock domains and handling them is one of the major things FPGA/ASIC designers need to understand, and it takes a while. --- Quote End ---
