Altera_ForumHonored Contributor13 years agoDevice support not install for web edition sp2 So, what's the correct procedure for installing a service pack for the web edition of Quartus? I installed 12.0sp2 after 12.0. When I launch sp2, I get: "You successfully installed the Q...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
