Determining the Max payload size encoding
- 3 years ago
Thanks for correcting me, my apologize for misunderstanding the question.
For your information the spec is not owned by intel, it is a general spec that all PCIe IP need to follow.
You can get the detail in "PCI Express® Base Specification" in the web.
For your question, I do help to printscreen it to you.
Max rd req sizeMax payload size
Hope this answer your question, Let me know if this is helpful to you.
Wincent_Intel
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Wei Chuan
From low level description, it is part of the Transaction Layer (TL) bus provides a subset of the information stored in the Configuration Space. Those Information on the Transaction Layer (TL) bus is time-division multiplexed (TDM). When tl_cfg_func[1:0]= 2'b00, tl_cfg_ctl[31:0] drives PF0 Configuration Space register values for eight consecutive cycles. The next 40 cycles are reserved. Then, the 48-cycle pattern repeats as per mention in the user guide.
Can I know is there any specific reason asking that question ? do you facing problem on the configuration ?
Wincent_Intel
- pdewanga3 years ago
The text you copy and pasted is from user guide, that we have gone through.
There is no issue of configuration. I just want to use this two following signal for our design.
[5:3] Max rd req size
[2:0] Max payload size
Actual question to make you more clear-
question:- Please share more details about the encoded value of this signals ( [5:3] Max rd req size [2:0] Max payload size ). What does each state means ?
Please don't copy paste the user guide content, We have gone through that but nothing is listed there properly.
- Wincent_Altera3 years ago
Wincent_Intel- pdewanga3 years ago
Hi wchiah,
Thanks for providing answer.
Piyush
