12 years agoDesigning with low level primitives
I am trying to get a Time to digital converter to work in my FPGA (like many before but no one actually posted the solution). I know that the base for everything is the LAB, containing 16 LE, which each has 2 LUT and a DFF and some other control logic. My gate level simulation is working but i am confused with the use of the CARRY_SUM primitive. If i understand correctly you have to place this primitive between the registers you want to connect through the internal (fast) carry path. e.g. Logic_1(out)-> CARRY_SUM => Logic_2(in) and in synthesis it is supposed to use the carry line. However it doesn't. It uses an input of the LUT which simulates with a delay between 300-800ps. Carry is supposed to be well below 100ps. The Cookbook uses "stratixii_lcell_comb" but i couldn't find any clear documentation nor if it also works in Cyclone. And i am using VHDL and cookbook examples are all verilog. :( Can anyone provide an example of successful usage of the CARRY_SUM primitive?
