Randal and Rysc,
Ohww, the secrets are coming.
Okay, now keep in mind a couple/few things;
1. As pointed out to me undocumented capabilities can be changed or removed at any time.
2. This worked for me in Q2 v7.0. Although Logic Lock, the old way with back anno., didn't work well this part DID!
3. You've really got to know the available Global and/or Regional resources available as well as their distribution withing the chip. You must plan ahead for this.
Example; Stratix2 Device Handbook Volume 2 pages 1-62 and 1-63 Figures 1-39 and especially 1-40 has the kind of information one needs to start this.
4. What worked best from it was when I imported the back-annoed LL region these Global settings came in successfully to the top level.
Okay.
'To start with after, at least, an Analysis and Elaboration I always go into Assignment -> Settings -> Timing Analysis Settings -> Classic Timing Analyzer Settings -> Individual Clocks and describe all the signals that will be used as clocks.
Next I'll go into the Assignment Editor and load those same signals into the To column. I also get the outputs of any PLLs here as well and any Global Resets and/or Preset signals. In the Assignment Name column set the Global Signal setting. In the Value column set the Global, Regional, Dual-regional, On, etc.
Now both the above steps you perform in both the top-level and lower-level functions. The lower-level you only need those resources your design is using but keep the declarations the same in both levels.
Next will be a Full-Compilation. Lets say you just do this in the lower-level for now.
After the Full-Compilation go into the Assignment Editor again. In the To column do a Post-Compilation node search for the signals you declared as Global Signals.
Here's the interesting part: what you want to choose is the signal that you're after but with a ~clkctrl (or is it ~clkctrl_g ?) (for Global) or ~clkctrl_r (for Regional) and select them!
(Now there is also a ~clkctrl_d, and a ~clkctrl_f as well but exactly what to set for a Dual-Regional resource I could not get an answer to and Stratix2's don't have the fast resources so I don't know about them as well.)
Do note that those Resets and/or Presets will also have the ~clkctrl.
Anyhow choose those signals inot the To column.
In the Assignment Name column select the Location setting.
In the Value column type in (capital letters) CLKCTRL_G# where# is the number of the Global resource you want this signal distributed on. For Regionals CLKCTRL_R# . As I said I don't know what to really enter for _D and _F.
Example; In the Floorplanner I see the 500Mhz input clock signal coming in as LVDS on pins T1 and T2 in my EP2S601020 device. That dedicated clock input can go directly to Global clock resources 7 or 8. I choose G8. So in the Value column I set CLKCTRL_G8
Save and full recompile. Now in v7.0 after the compile the signal would be marked with a diamond and "?". I was specifically told that that labeling was a software bug so don't worry it.
Doing the old way of Logic Lock these settings did import into the top-level successfully. So well that different lower-level functions done this way and using the same signals all connect to the same Global resource at the top level as viewed with the Floorplanner after post top-level Full-Compile. If there are issues open the Assignment Editor at the top-level and look through to make sure all the ~clkctrl settings for a specific signal are the same. If not then correct it there and compile again.
Where my design failed was, by compilation error and SR feedback on it, the use of Logic Lock with back annotation. This stuff here was okay.
I don't know if this works yet in v7.1 and with ID but I'll be finding out.
Have fun guys!
