10 years agoDesign Unit Not Found
Hello all,
I'm still trying to get my *first* simulation running with ModelSim, and my progress is quite limited. I think I have my license issues worked out finally, after talking directly to Altera support. Currently, I am trying to run simulations on my project, but am getting errors. whenever I try to simulate anything (right click on module in my work dir and select simulate), I get the following:ModelSim> vsim work.TX_PLL# vsim work.TX_PLL # Start time: 17:52:30 on Mar 09,2016# Loading work.TX_PLL# ** Error: (vsim-3033) D:/Users/Nicholai/Desktop/Research/QuartusII/March2016/DACSimulation/TX_PLL.v(75): Instantiation of 'altpll' failed. The design unit was not found.# Time: 0 ps Iteration: 0 Instance: /TX_PLL File: D:/Users/Nicholai/Desktop/Research/QuartusII/March2016/DACSimulation/TX_PLL.v# Searched libraries:# D:/Users/Nicholai/Desktop/Research/QuartusII/March2016/DACSimulation/simulation/modelsim/rtl_work# Error loading design# End time: 17:52:31 on Mar 09,2016, Elapsed time: 0:00:01# Errors: 1, Warnings: 0 I found a lot of threads with similar problems, but haven't figure out the solution. I am not sure where the library for 'altpll' is. I do have a huge list of libraries in the library pane. Is there an easy way to know what library my cores are from? Once I figure out what library altpll is in, when do I use the include directory command? Should that go in my .do file? Not a single one of my modules will simulate- I am using: ROM: 1-Port LPM_COUNTER ALTDIDO_OUT ALTPLL I am using a Stratix IV device. Sorry if this is a very easy question to answer, I have never used this tool (or hardly any Altera tools) before. Right now, I have nothing set up and working. I'd like to get to the point where I have a testbench. Thank you, FrenchyRaoul14 Replies
Or you could do vcom on dac_top.vht?
--- Quote Start --- Hello, No. .vht stands for VHDL test bench file while vlog command compiles Verilog source code and SystemVerilog source codes. Hence it will not work. You should try following :- In Quartus, Go to Assignments -> Settings... -> EDA Tool Settings -> Simulation. In that select 'Verilog' under 'Format for Output Netlist'.
- In Quartus, Go to Processing -> Start... -> Start Test Bench Template Writer This should now create dac_top.vt file in same folder in which dac_top.vht file was being created before.
- Now try following command: vlog -reportprogress 300 D:/Users/
vlog -reportprogress 300 D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/simulation/modelsim/dac_top.vt# Model Technology ModelSim ALTERA vlog 10.4b Compiler 2015.05 May 27 2015# Start time: 21:03:15 on Mar 28,2016# vlog -reportprogress 300 D:/Users//Desktop/Research/QuartusII/March2016/DACSimulation/simulation/modelsim/dac_top.vt # -- Compiling module dac_top_vlg_tst# # Top level modules:# dac_top_vlg_tst# End time: 21:03:16 on Mar 28,2016, Elapsed time: 0:00:01# Errors: 0, Warnings: 0 - Altera_Forum
@ mikedsouze,
Thank you for sharing idea about vcom command. It could have solved problem more easily. @ FrenchyRaoul, We are glad to hear that you are close to your goal. Cheers, Bhaumik - Logic5150
Another possible cause of this error is when you have your top level name and the corresponding file name different from the module name .
For example,
TOP_LEVEL_NAME=testbench, corresponding file name=testbench.sv.
module you declared inside testbench.sv=module testbench_top;.
