gbassi
6 years agoDesign Space Explorer segmentation violation
Hi all,
recently I am experiencing a segmentation violation error when trying to compile a Quartus project with the DSE. The single compilation is completed correctly by Quartus, from Analysis&Synt...
- 6 years ago
Can you try running DSE using command line ?
KhaiY
KhaiChein_Y_Intel
6 years agoHi,
KhaiY
gbassi
6 years agoDear @KhaiChein_Y_Intel ,
thanks a lot for your answer.
Running DSE using command line works!
Do you know if there is an explanation for this behavior?
I am asking because the same problem may affect other components/processes in Quartus.
Thank you
Giovanni
