RPett4
7 years agoDesign Partitions and Fitter run-time
Should implementing design partitions speed up the fitter run time? I have my entire design split into about 9 blocks, all set for "Default" type Design Partition with "Preservation Level" of "final"...
RPett4
7 years agoBut the part I am changing is NOT in a partition. None of the code related to the 9 partitions changed.
You didn't really address my question: Should the fitter run time take the same amount of time as not using partitions?
