RPett4
7 years agoDesign Partitions and Fitter run-time
Should implementing design partitions speed up the fitter run time? I have my entire design split into about 9 blocks, all set for "Default" type Design Partition with "Preservation Level" of "final"...
KennyT_altera
7 years agoThanks, if you set the design partition to Final. Quartus will not take any changes into account in your verilog code. Unlike Standard edition.
You need to change back your partition to source first then to final again.
