Design Example for LVDS rx in MAX10
Hi ,
Initially i want to detect an 12'hE9C idle pattern for some clock cycles (ex: 282 clocks), output of lvds rx ip output is 6 bit and i am using shift register to convert 6 bit to 12 bit.
required output E9C = 111010011100 .
sometimes i receive: 110100111001, 100111010011, like that for every power on bit position was changing from one position to other position.
Now i need to write bit slip logic using state machine or in Quartus has any built solution for this.
manoj
Hello Manoj,
You can refer to Data Realignment Block (Bit Slip) in this document on page 27: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_lvds.pdf
Thank you
- AminT_Intel5 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
