14 years ago
Delaying signals
Hey,
Firstly I'd like to mention that I'm a beginner in fpga programming :)
I will use a simple example to show exactly what I'd like to know:
(It turns out that I'm not allowed to post images or links so I used the Attach Files option)
As you can see, when there's a rising edge on clk2, the clk0 hasn't yet changed it's state.
What I would like to know is it possible to delay the clk2 signal so that when there's a rising edge on it, the clk0 had already changed. (Using TimeQuest analyzer!!!)
I know that it's possible to set an offset to clk2 in the ALTPLL but I wanted to know is it possible to solve this problem TimeQuest Analyzer.
I tried to set clock latency and net delay, etc but nothing seemed to work. I guess that I just don't understand everything right :)
Hope that someone will help,
Thanks in advance!
1 Reply
    dont go putting clocks through logic. That wont help and the skew will change with temperature and other factors.
    Use the delay on the PLL to phase shift a clock to the amount you need.
