8 years agoDelaying all incoming signals by 2 ms using VHDL
Hi to all, I'm a finance student and I'm also interested in electronics, these days I do program because my limited of knowledge of this, so ask for help in here.I have two incoming signals that I wa...
8 years ago --- Quote Start --- (1) Is it possible to maintain temporal accuracy (down to very few nanoseconds) when using a FIFO buffer to delay one of the incoming signals, or will sending the signals into the buffer lose that accuracy and only share rising/falling edges with my clock? (Does the buffer say that block of data is either entirely zero or entirely 1, depending on whether the signal was in a high or low state at the rising edge of the clock when it collects the data?) --- Quote End --- This is going to be the tricky part ... to maintain 2ns sampling accuracy requires a 500MHz clock to the sampling circuit (or 3ns at 333MHz). Depending upon the device this may or may not be achievable; it is at the high (or beyond) end of most device PLLs. The maximum clock tree frequency for the C6 (fastest) speed grade CycloneIV device (as used on a DE2 board) is listed as 500MHz. So it will be quite a challenge for you to do that.
