10 years agoDefining an array of bytes with a dynamically allocated size
Can anyone tell me how to define an output to an entity, which is an array of bytes and has a size specified by a generic parameter. I have written a code snippet below which doesn't work but demonstrates what I want to do, and another code snippet which does work but is not generic and cannot be altered dynamically. What I want, but does not work library ieee;
use IEEE.numeric_std.all ;
entity My_entity is
generic (No_of_Bytes : integer := 5);
port (Entity_output : out array(No_of_Bytes-1 downto 0) of unsigned(7 downto 0) );
end entity;
Works but is not generic library ieee;
package Array_Type_Definition is
constant No_of_Bytes : integer := 5 ;
type TArray is array(No_of_Bytes-1 downto 0) of unsigned(7 downto 0) ;
end package Array_Type_Definition ;
library ieee;
use work.Array_Type_Definition.All ;
entity My_entity is
port (Entity_output : out TArray);
end entity;2 Replies
arrays can be defined in a package without a length (as long as the "internal" arrays are all length defined pre VHDL2008)
type TArray is array(integer range <>) of unsigned(7 downto 0) ; and then in the entitiyentity My_entity is generic (No_of_Bytes : integer := 5); port (Entity_output : out TArray(No_of_Bytes-1 downto 0); end entity; - Altera_Forum
Thank you, Tricky. Worked perfectly.
