Decrypt verilog file
How can I read an IEEE 1735 encrypted file (vendor specific key) into Quartus Pro 2021.3?
The compiler outputs the following error messages:
Info: ******************************************************************* Info: Running Quartus Prime Synthesis Info: Version 21.3.0 Build 170 09/23/2021 SC Pro Edition Info: Processing started: Wed May 11 16:28:24 2022 Info: System process ID: 29918 Info: Command: quartus_syn --read_settings_files=on --write_settings_files=off counter -c counter Info: qis_default_flow_script.tcl version: #1 Info: Initializing Synthesis... Info: Project = "counter" Info: Revision = "counter" Info: Analyzing source files Error (13223): Verilog HDL or VHDL error: No key to decrypt data block Error (13223): Verilog HDL or VHDL error: decryption of data_block failed Error (17390): Verilog HDL error at counter.vp(13): error in protected region near / File: counter.vp Line: 13 Error (13223): Verilog HDL or VHDL error: No key to decrypt data block in file counter.vp Error (13223): Verilog HDL or VHDL error: decryption of data_block failed Info (19551): Verilog HDL info at counter.vp(41): endmodule File: counter.vp Line: 41 Info (19551): Verilog HDL info at counter.vp(41): ^ File: counter.vp Line: 41 Error (13411): Verilog HDL syntax error at counter.vp(41) near text endmodule File: counter.vp Line: 41 Error (19645): Verilog HDL error at counter.vp(41): SystemVerilog keyword endmodule used in incorrect context File: counter.vp Line: 41 Error: Flow failed:
Thanks in advance & Best regards,
Alex
- ShengN_altera
Hi Alex,
If the design file is encrypted by third-party, probably have to get the IEEE 1735 specific encryption key for synthesis.
Best Regards
Sheng
- ShengN_altera
Alex,
If you already have the encryption key, do the followings:
- Encrypt the design with IEEE 1735. Command line used: encrypt_1735 --quartus --language=verilog counter.v
- File counter.vp will be generated in the file folder.
- Open a new project, add counter.vp in the project. Set it as top-level entity.
- Right click on the counter.vp. Select Properties. Ensure the Type: Verilog HDL File.
- Run Analysis & Synthesis.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- Alexander_Kobler
the file in the example was encrypted using Cadence' xmprotect, using IEEE 1735 encryption and a vendor specific key. As Quartus Pro supports IEEE 1735 en/decryption as well, it should be possbile to compile the file with Quartus, or am I wrong?
Alex
- ShengN_altera
Hi Alex,
May check out this link https://www.intel.com/content/www/us/en/docs/programmable/683463/22-1/support-for-the-ieee-1735-encryption.html
Only file encryption with a third-party tool requires the public encryption key. File encryption with the Intel® Quartus® Prime Pro Edition software does not require the public encryption key.
Probably you have to get the public encryption key for encryption with third-party tool.
Sheng
- ShengN_altera
Hi Alex,
May I know any further update or concern?
Do you need further helps on this case?
Thank you.
Sheng
- ShengN_altera
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
