12 years agodeclaring port as array type
How to solve a problem with declaring port as array type?
I want to make entity multiplexer like this:entity multiplexer is
generic(
sel_bits: integer := 2;
data_width: integer := 1
port(
input: in array (2**sel_bits-1 downto 0) of bit_vector(data_width-1 downto 0); -- this won't do. I could use package, but is there this kind of solution?
output: out bit_vector(data_width-1 downto 0);
sel: in bit_vector (sel_bits-1 downto 0)
end entity multiplexer;
you cannot declare an array like that. First you need to declare the type and then create a signal of that type. In this case you will need to declare the array type in a package.
type my_array_t is array(2**sel_bits-1 downto 0) of bit_vector(data_width-1 downto 0); --in the port input : my_array_y; The upshot of this is that you will need to decalre the generics as constants in the package also. - Altera_Forum
Or for more flexibility you could define your own array type using an unconstrained array (VHDL-2008). Define it in a separate file like this:
Include it in the library sectiontype StdLogicVectorArray is array(integer range <>) of std_logic_vector;
Now you are able to use it for your port like this:library work; use work.MyTypeFile.all;
Hope that helps. Regards, Sörenport( input : in StdLogicVectorArray(0 to (2**sel_bits-1))((data_width-1 downto 0) downto 0); (...) ); - Altera_Forum
I was hoping it would help, but
isn't correct. It says that std_logic_vector is unconstrained, or something like that... When I try to constrain it withtype StdLogicVectorArray is array(integer range <>) of std_logic_vector;
and use it in code like thistype StdLogicVectorArray is array(integer range <>) of std_logic_vector(0 to 100)
it complains that element type in StdLogicVectorArray is constrained, so I can't do that. Now what?port( input : in StdLogicVectorArray(0 to (2**sel_bits-1))((data_width-1 downto 0) downto 0); (...) ); - Altera_Forum
You need to set he vhdl version to 2008 in the project settings.
Cool, it works. Thank you.
