12 years ago
Decision scheme
Hi ,
I design decision scheme in order to determine whether the signal i '0' or '1' from group of 4 bits and then the output signal of the scheme change respectively .
for some reason the output signal Des_out is persistently '0' .
The VHDL code is :
--process - decision scheme '0' or '1'
process (ResetP)
variable score : integer range 1 to 4;
begin
score := 1 ;
if ( resetP = '1' ) then
Des_out <='0';
elsif ( clk_100M'event and clk_100M='1' ) then
for ind in 0 to 3 loop
if hlp(ind)='1' then
score := score + 1;
end if ;
end loop ;
if (score > 2) then
Des_out <= '1';
else
Des_out <= '0';
end if ;
end if ;
end process;
what is wrong in the design ?why does Des_out is consistently '0' ?
does the design have to be depend in the clock event or it will change for every change in the group of 4 bits ?
how can i watch at variable score and ind during the simulation ?
Visio file attached - look at Desicion scheme (the rest is at other process) .
wave photo attached - Des_out = '0'
    It takes time to see the whole code but I insist on majority circuit is a combinational one. An alternative vhdl is:
    Des_Out <= '0' when ( hlp = "0000" ) else
    '0' when ( hlp = "0001" ) else
    '0' when ( hlp = "0010" ) else
    '0' when ( hlp = "0011" ) else
    '0' when ( hlp = "0101" ) else
    '0' when ( hlp = "0110" ) else
    '1' when ( hlp = "0111" ) else
    You don't need any process nor variables. It's a brute force method but it works. It's the copy of the truth table of majority circuit on the code.
    --- Quote Start ---
    I post a code with variables and a pure combinational majority circuit. The testbench shows "test_dataout" goes high after few clocks.
    --- Quote End ---
    thanks bertulus , you help me a lot .
