16 years ago --- Quote Start --- Hi GPK, what you descibe is pritty much what I was doing but am getting the following warnings when I start the simulation. Info: Using vector source file "vhdl/peripherals.vwf" Warning: Can't find node "tst_peripherals_trans:uut|counter[3]" for functional simulation. Ignored vector source file node. this internal node is a register so bit surpried that it cannot be found - any ideas? thanks, John. --- Quote End --- Hi John, did you choose "post-synthesis" Nodes ? Kind regards GPK
