16 years ago --- Quote Start --- Hi, I have designed a simple block to be programmed onto FPGA. Currently there is a bug which I am trying to find - I am using the quartus simulator and would like to know if annybody knows how to setup the simulator so that I can view internal signal values after the simulation has completed. Can find in manual. So far I can only get it to report the values of the top level pins which is not helping me. Thanks in advance! --- Quote End --- Hi, you have to define the signals in your <>.vwf. Open the file and: double-click into the "Name" column A new window pops-up "Insert Node or Bus" Click on "Node Finder" and choose your signals Kind regards GPK
