--- Quote Start ---
But additonal channels doesn't appeared in console. What additional jobs required for this situation?
--- Quote End ---
If the fitter results confirm you have the right number of channels, then the issue is probably just the Transceiver Toolkit GUI.
Click on the "Setup" button in the GUI and create the channels. You can save the setup as a Tcl script and load it next time you start the GUI.
If you are using 14.0, then delete all the existing channels and start from scratch. In the examples I tried, the GUI would not interface to the transceiver registers correctly using any of the default channels.
Cheers,
Dave
