I also have the SDRAM Controller but I don't know which one of the following Avalon to use or am I looking in the right place?
- Avalon-MM Clock Crossing Bridge
- Avalon-MM DDR Memory Half Rate Bridge
- Avalon-MM Pipeline Bridge
- Avalon-MM Tristate Bridge
- JTAG to Avalon Master Bridge
- SPI Slave to Avalon Master Bridge
--- Quote Start ---
I clearly see in my QSYS a component called "SDRAM Controller". You have 2 options: export Avalon MM interface from QSYS to Quartus or add your custom peripheral to QSYS.
--- Quote End ---
I don't understand what you mean by export "Avalon MM interface from QSYS to Quartus" The way I understand QSYS is that you need to build the whole system before you can successfully export the modules. Or do you mean I have to import Avalon MM interface from somewhere?
