12 years agoDE2-115 DDR2 Controller
Hi everyone!
I'm currently working on an implementation that requires me to store packets into the SDRAM then fetch it when it is optimal to transmit. I am having trouble on making it work though. The way I understand it, I have two options.- Use NIOS through QSYS then access the memory using C programming.
- Use AVALON INTERFACE and MegaWizard to generate the necessary IP.
i want to extract the data from the memory to a logic outside the nios system. in essence, i am just using the nios to access the memory because this is the easier tutorial that i have found online. however, it lacks the succeeding steps.
for the avalon:
AVALON MEMORY MAP INTERFACE Chapter 3. Avalon Memory-Mapped Interfaces http://www.altera.com/literature/manual/mnl_avalon_spec.pdf Embedded Peripherals IP USER GUIDE Chapter 2. SDRAM Controller Core http://www.altera.com/literature/ug/ug_embedded_ip.pdf External Memory Interface Handbook - Volume 2: Design Guidelines Chapter 9. Implementing and Parameterizing Memory IP http://www.altera.com/literature/hb/external-memory/emi_plan.pdf From this, I have deduced that the SDRAM controls will be handled by the IP built by Altera, and the only thing that I should have problem is utilizing the Avalon-MM Slave Port. This might be a good idea for developers who are already familiar with altera because the Avalon interface is used in many IP but since this is my first time to use such interface, I am lost on how to proceed. i know that this is a more straight forward approach but i can't find the right timing diagram to create an fsm that will utilize the signals. moreover, i need more information on each control and data signals. on top of that, during the creation of the ip with megawizard, i don't have any idea on what to put into the parameters of the sdram because the de2-115 did not specify what chip it is. Here are the information that I know about the SDRAM in DE2-115.
- DDR2 - 128MB
- 16 data lines shared for both SDRAM making it access 32 bit of data per address locations.
- It has 13 address lines and 2 address lines for the banks.
- Address Banks = (2^13) (2^10) (2^2) = 8192 1024 * 4 = 33554432 address locations = 32M
- 32M words x 32 bits/word = 1028 Mbits = 128MB
