8 years agode0 Nano ADC interfacing
Hi all,
Im trying to interface with the ADC on the de0 nano, with a simple program to start with: -Turn on LEDs if ADC value > 1.5V -Turn off LEDs if ADC value <= 1.5V It seems that I have something fatally wrong with my program, as my LEDs get turned on every time with 0V going into the adc. They even turn on if I flip the < and >= sign; meaning something must be very wrong indeed. The following snippits are all from the same Module, which compiles and transfers fine to the fpga Im using page 3 of this document as a reference: ftp://ftp.altera.com/up/pub/altera_material/12.1/tutorials/de0-nano/using_de0-nano_adc.pdf I basically have three "events": -Posedge of master clock: (1) generate clock signal for adc, manage cs signal going to adc -posedge of adc clock: (1)write led values (2) read adc bits -negedge of adc clock: (1) write adc channel number to adc First, the inputs/outputs and the local vars:
module blinky2 (input clk,
output reg led, //output to led
output reg sclk, //clock signal for adc, generated by this module
output reg cs=1, //communication channel to adc,
input dout, //data from adc
output reg din); //communication to adc, for channel selector
//local variables
reg counter=1;
reg adcClkCycNum=0;//the adc cycle number, 16 step process.
reg adcChNum=0;//the ADC channel number for use with din; set to 0 for now
reg adcSample=0;//12 bits for storing the digitized adc sample
Next, the generation of the sclk signal, which is the clock signal provided to the adc: Merged into this is also management of the CS signal, which needs to be changed on both the positive and negative edge of the adc clock signal (so we manage it here, instead of on posedge/negedge of adc clock signal. always @ (posedge clk)
begin
if (counter == 1)
begin
counter <= 25; //dividing the master clock clk by 25 to generate adc clock signal
if (adcClkCycNum == 0) //cs must be set low on the lower edge of cycle 0
begin
if (sclk == 1)
begin
cs<=0;
end
end
if (adcClkCycNum == 15)//cs must be set high on the rising edge of cycle 15
begin
if (sclk == 0)
begin
cs<=1;
end
end
sclk <= ~sclk;
end
else
begin
counter <= counter -1;
end
end
Next, the things that happen on the positive edge of the adc clock: This includes reading the sample from the adc, and setting the LEDs
always @ (posedge sclk)
begin
begin
if (adcSample==150)
begin
led<=250;
end
adcClkCycNum<=1;
end
if (adcClkCycNum == 1)
begin
adcClkCycNum<=2;
end
if (adcClkCycNum == 2)
begin
adcClkCycNum<=3;
end
if (adcClkCycNum == 3)
begin
adcClkCycNum<=4;
end
if (adcClkCycNum == 4)
begin
adcSample<=dout;
adcClkCycNum<=5;
end
if (adcClkCycNum == 5)
begin
adcSample<=dout;
adcClkCycNum<=6;
end
if (adcClkCycNum == 6)
begin
adcSample<=dout;
adcClkCycNum<=7;
end
if (adcClkCycNum == 7)
begin
adcSample<=dout;
adcClkCycNum<=8;
end
if (adcClkCycNum == 8)
begin
adcSample<=dout;
adcClkCycNum<=9;
end
if (adcClkCycNum == 9)
begin
adcSample<=dout;
adcClkCycNum<=10;
end
if (adcClkCycNum == 10)
begin
adcSample<=dout;
adcClkCycNum<=11;
end
if (adcClkCycNum == 11)
begin
adcSample<=dout;
adcClkCycNum<=12;
end
if (adcClkCycNum == 12)
begin
adcSample<=dout;
adcClkCycNum<=13;
end
if (adcClkCycNum == 13)
begin
adcSample<=dout;
adcClkCycNum<=14;
end
if (adcClkCycNum == 14)
begin
adcSample<=dout;
adcClkCycNum<=15;
end
begin
adcSample<=dout;
adcClkCycNum<=0;
end
end
And finally, the events that occur on the negative edge of the adc clock: This includes sending the adc channel number to the adc in steps 2-4 always @ (negedge sclk) begin
begin
end
begin
end
begin
//adc channel number, addr2
din<=adcChNum;
end
begin
din<=adcChNum;
end
begin
din<=adcChNum;
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
begin
end
end
Ive got all the pinouts selected per the Altera manual. My guess is that I have many things fatally wrong with this program. This is my first time trying to interface with an adc. Any suggestions? Thanks all2 Replies
You don't set the initial value of led, and you don't have any code that would turn LEDs back off once they are on. There's one assignment that turns most of them on if adcSample is equal to 150 at any moment (however briefly), and after that LEDs remain in that state permanently.
--- Quote Start --- You don't set the initial value of led, and you don't have any code that would turn LEDs back off once they are on. There's one assignment that turns most of them on if adcSample is equal to 150 at any moment (however briefly), and after that LEDs remain in that state permanently. --- Quote End --- Thank you!! That was it. This is my first time writing an fpga routine, cant believe that was my only mistake to be honest... all working now! thanks!
