DDR3 MPFE timing constraints
Dear DBart1,
Thank you for joining this Intel Community. I am truly apologize for the delay in response due to long holiday in my region.
The issue you are facing is a known issue but it is not fix in the IP. As a workaround, we have published a KDB on how to cut the failing path in this link --> https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd08142014_213.html
Hope this helps.
NAli1
- DBart17 years ago
Is the KDB mentioned somewhere in the User guide or other place that I missed? I am a little confused when using the IP what information is needed to be reviewed. There are 364 KDB articles that show up when search for DDR3. Why wouldn't this be mentioned in the IP User guide if it is a known issue?
