14 years agoDDR2 HPCII v11.0 problem, thanks for help !
everything seems well, however, local_init_done is always low, what's wrong? I tried both the full calibration and "skip the calibration", it doesn't change anything, the local_init_done is alway...
11 years ago --- Quote Start --- Can anybody please answer this? I am having teh same problem. Is there any specification for the global and soft reser I have connected global to 2ms low pulse, and soft is always high Calibration does not pass for me either --- Quote End --- Did you check your schematic? Is the memory connected properly? The design synthesizes and passes timing fine?
