Come into the input, then feed your 8 F/F and floorplan the 8 F/F to be right next to the I/O cell on the die.
This should help control the route delays.
The real challenge is that you will be using 8 different clocks (related by phase), each FF will need to be in a different LAB.
To help control the route delays, you can then set a very "almost" undo-able SDC constraint on the incoming part to force the tool to work real hard to meet all the parallel timings. (turn on timing driven options).
Good luck with this, and keep us informed.
