13 years agoHi,
Using this project you will have to create a SOPC block with your block diagram (that one that makes the 32 bit operations) and than connect it to the SOPC project of the example, because this uses a NIOS to interface the TSE MAC, so this block you will create will interface with the NIOS. But if you want to avoid NIOS and SOPC will you have to instantiate the TSE alone using MEGAFUNCTION.
