16 years ago
Data Clock Race conditions
Hello everyone,
I am trying to connect two Altera Stratix II boards together through a custom 2-bit serial connection. Right now I send the clock (along with the data) from board 1 to board 2 so that the data can be sampled at the same clock remotely. Then I perform a clock domain translation on board 2 using a two-flop synchronizer.
The problem is that the data bits sent out from board 1 (as seen on the Logic Analyzer) are different from the data bits received on board 2 (as seen on LA). I am using the same clock to run both LAs so I assume the data bits should appear to be the same.
Since they are not, so I thought there must a race condition occurring between the clock and the data so I started sampling on the neg edge of the clock on board2. It has improved, but still sometimes the data bits are skipped or received twice. Entire system operates on a standard 50 MHz clock... I have tried many different things but its still not stable. Any suggestions/advice would be highly appreciated.
Btw, in the info after compilation the following msg is shown where sys_clk is the board 1 clock and sndr_clk_UR_LR_A is the signal that carries the clock to the remote board:
"Info: Longest tpd from source pin "sys_clk" to destination pin "sndr_clk_UR_LR_A" is 11.467 ns
Info: 1: + IC(0.000 ns) + CELL(1.063 ns) = 1.063 ns; Loc. = PIN_AF15; Fanout = 2; CLK Node = 'sys_clk'
Info: 2: + IC(8.021 ns) + CELL(2.383 ns) = 11.467 ns; Loc. = PIN_C21; Fanout = 0; PIN Node = 'sndr_clk_UR_LR_A'
Info: Total cell delay = 3.446 ns ( 30.05 % )
Info: Total interconnect delay = 8.021 ns ( 69.95 % )"
Thanks in advance !!!
