There could be a great many things wrong with it ... but you haven't posted a sufficient amount of code.
For example the statement Q <= 0 is not valid for std_logic, it should be Q <= '0', but then again, perhaps you have included a conversion library ...
Post a complete example, rather than a code snippet.
Here's how I would normally write this piece of code;
-- Start with only this library (you can get fancy later)
library ieee;
use ieee.std_logic_1164.all;
process(clk, reset)
begin
if (reset = '1') then
q <= '0';
elsif rising_edge(clk) then
if ((a = '1') and (b = '1')) then
q <= d;
end if;
end if;
end process;
Note the use of elsif, and also note that I've assumed a and b are std_logic, so to turn them into boolean I've compared them with a std_logic '1'. I do this out of habit, the syntax you have used might be allowed with VHDL-2008. Play with this example and see what you are allowed to do and what you cannot.
Cheers,
Dave
