BrianM
5 years agoCyclone V: FPGA to SDRAM interface not working
Hello.
Part: Cyclone V 5CSXFC5D6F31C7, about 85% utilized.
I've written RTL in verilog for a simple MM interface from the FPGA to SDRAM 1 HPS interface. I created a test bench utilizing an MM DRA...
BrianM
5 years agoQuick update: I removed the PCIe stuff from the Platform Designer file and attempted to generate a test bench for just the HPS and my FPGA implementation.
Now I get this error:
Error: fpga_interfaces: add_fileset_file: No such file /opt/intelFPGA/20.1/ip/altera/mentor_vip_ae/axi3/bfm/mgc_common_axi.sv while executing "add_fileset_file mgc_common_axi.sv SYSTEM_VERILOG PATH $MENTOR_VIP_DIR/axi3/bfm/mgc_common_axi.sv" ("if" then script line 3) invoked from within "if {$include_axi_bfm} { add_fileset_file questa_mvc_svapi.svh SYSTEM_VERILOG PATH $MENTOR_VIP_DIR/common/questa_mvc_svapi.svh add_fileset_..." (procedure "add_files_to_simulation_fileset" line 33) invoked from within "add_files_to_simulation_fileset $data(interfaces)" (procedure "sim" line 41) invoked from within "sim CPU_Subsys3_sim_hps_0_fpga_interfaces"
