indu_man
3 years agoCyclone IV ISSI 256 Mb flash .jic file not working
though its an old thread, however we are encountering a similar issue with IS25LP256D flash. This is ISSI 256Mb flash connected with Cyclone IV EP4CGX75 FPGA.
Using the blow guidance (in ...
indu_man
3 years agoHi,
I have mentioned the part number of the flash IS25LP256D .
Here is the datasheet link.
https://www.issi.com/WW/pdf/IS25LP(WP)256D.pdf
However, yesterday I found out in the Generic Flash Quartus Programmer User Guide that Cyclone IV only supports 3-bytes addressing.
Hence I concluded (and may be you can confirm ) that the flash of 256 Mb size from ISSI is simple not compatible with the Cyclone IV.
Is there a way around this?
I can try to program the flash to use 3-byte addressing, however in this case the flash size should be 128 Mb. Is there a trick to achieve that the tool (Quartus programming tool) takes it as a 128 Mb flash and not a 256 Mb flash?
Best Regards
Adnan
