17 years agoThe said synchronous flash interface pins exist as dedicated AP pins in Cyclone III, as the Configuration Handbook clarifies. So there shouldn't be a problem where to connect the pins. I don't know, if they are also supported by other flash related IP, apparently not in PFL Megafunction. This means, that the PFL access to Intel flash is asynchronous only.
