14 years agoCyclone III LS doesn't boot w/o ByteBlaster
I am using a Cyclone III LS, using JTAG to program during development, and a Serial Configuration Device to load the FPGA once that is finished.
I programmed the .jic file into the SCD in order for a colleague (who does not have Quartus) to test the board without having to program after every powerup. The board had no function unless the ByteBlaster was connected to the JTAG connector. The ByteBlaster did not need to be connected to USB for this to work. I've attached my JTAG connector pinout. This should be correct, since programming with the .sof poses no problems. I have also attached the schematic showing the resistors on the JTAG lines, connected per the Cyclone III Device Family Pin Connection Guidelines. TMS is pulled up to 2.5V with a 10K resistor. TDI is pulled up to 2.5V with a 10K resistor. TCK is pulled down to GND with a 1K resistor. TDO has no resisitors on it. If anyone has any clues to a permanent solution, I would be grateful!
