16 years agoCyclone II SDRAM connectivity
Hi - thanks in advance for reading.
I'm trying to load the count_binary program onto the Cyclone II board using Nios II; I've received several errors, the most common being:Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloading 02000000 ( 0%)
Downloaded 61KB in 1.0s (61.0KB/s)
Verifying 02000000 ( 0%)
Verify failed between address 0x2000000 and 0x200F37F
Leaving target processor paused I've also seen the following: Hardware simulation is not enabled for the target SOPC Builder system. Skipping creation of hardware simulation model contents and simulation symbol files. (Note: This does not affect the instruction set simulator.) as well as a win32 error 487. This is an intro course and I'm not very familiar with troubleshooting techniques; any tips would be awesome. Thanks again :)
