16 years agoThe second message regarding hardware simulation is irrelevant I believe.
Your first problem is the larger problem. It would indicate that your interface to the SDRAM is not working properly. Either SDRAM is not connected properly or that you are not meeting timing requirements. Which board exactly are you using? Are you using an FPGA project that you created or one that came with the board? Jake
