--- Quote Start ---
Instead of searching
the web, you may want to ask the RAM Megafunction User Guide. It tells:
You have manually instantiated a ROM without a clock, or in other words, an asynchronous ROM. But it's not available with Cyclone II and any other newer FPGA families. By implementing the ROM through the MegaWizard, you can only choose port and parameter combinations, that are supported for the respective device family.
--- Quote End ---
Dear FvM,
I've tried to implement Rom using altsync MegaWizard but it doesnt put the input and output ports as i would like them to be. I need the ports to be as defined in the Rom file ive attached. Can you help me do that? please? i dont know how to go about doing that.
Dante
