Jeff9
3 years agoCyclone 10 GX EMIF Design Example: I/O assignment errors
I'm following the Cyclone 10 GX EMIF IP Design Example User Guide in the below web page.
1. Design Example Quick Start Guide for External Memory Interfaces... (intel.com)
The EMIF projec...
- 3 years ago
Hi Jeff,
No, you should not choose "Project Template".
I am thinking that you are not opened the generated example design.
If you are referring to Figure 3 in Section 1.3, there is a path to where the generated example design is created.
Usually, the project design is located in emif_0_example_design/qii/ed_synth.qpf
Can you check the design in this path?
Adzim
AdzimZM_Altera
3 years agoHi Jeff,
I am glad that you are successfully running full compilation.
Yes the example design project directory should always generated in qii folder. All the related files are included in this folder.
Adzim
