Cyclone 10 GX EMIF Design Example: I/O assignment errors
- 3 years ago
Hi Jeff,
No, you should not choose "Project Template".
I am thinking that you are not opened the generated example design.
If you are referring to Figure 3 in Section 1.3, there is a path to where the generated example design is created.
Usually, the project design is located in emif_0_example_design/qii/ed_synth.qpf
Can you check the design in this path?
Adzim
Hi Jeff,
Adzim
- Jeff93 years ago
Hi Adzim,
The compilation errors were found from "example_design\emif_example.qpf".
When I opened the project "example_design\emif_c10_0_example_design\qii\ed_synth.qpf", the full compilation is working.
Thank you so much. then, the below compilation step also indicates the qpf file under the qii folder?
1.8. Compiling and Programming the Intel® Cyclone® 10 GX EMIF Design...
Jeff
