Cyclone 10 GX EMIF Debug Toolkit, Error on Link Project to Device
- 3 years ago
Hi Jeff,
You do not to worry about Fitter location because the Fitter location is auto generated by Quartus.
The important thing here is the location must be able to pass the Fitter compilation.
After you have filled all location according to schematic, you can recompile the design again.
Adzim
Hi Jeff,
I believe you have to set the pin name in Location tab according to the your board schematic.
After you have placed all pins, you need to run full compilation again.
The snapshot below is the example of pin names in the Pin Planner window.
Adzim
- Jeff93 years ago
Hi Adzim,
Unfortunately, I haven't filled the location yet. The devboards GmbH designed it but the website stays inactive for long time. So, I can't download its schematics currently.
Jeff
