Cyclone 10 GX EMIF Debug Toolkit, Error on Link Project to Device
- 3 years ago
Hi Jeff,
You do not to worry about Fitter location because the Fitter location is auto generated by Quartus.
The important thing here is the location must be able to pass the Fitter compilation.
After you have filled all location according to schematic, you can recompile the design again.
Adzim
Hi Jeff,
You can use Pin Planner tool from Quartus to fitting the pin assignment.
There is multiple resources about Pin Planner but you may refer to this link as well:
https://www.intel.com/content/www/us/en/docs/programmable/683562/17-1/pin-planner.html
The pin location for memory device should be able to get from board schematic in IO Bank section.
You can fill up the location tab in Pin Planner with the location stated in the board schematic.
Adzim
