Jeff9
3 years agoCyclone 10 GX EMIF Debug Toolkit, Error on Link Project to Device
The EMIF project is created based on the below user guide. Compiling and programming on my board was fine. However, the EMIF Debug Toolkit can't link project to device with the below errors....
- 3 years ago
Hi Jeff,
You do not to worry about Fitter location because the Fitter location is auto generated by Quartus.
The important thing here is the location must be able to pass the Fitter compilation.
After you have filled all location according to schematic, you can recompile the design again.
Adzim
AdzimZM_Altera
3 years agoHi Jeff,
I may suggest to check on pin assignment of the design.
Try to place all the pins then rerun the compilation.
Then you may program the board again and run the EMIF Debug Toolkit.
Adzim
