Cycle approximate simulation using Intel FPGA opencl
You just described the single biggest roadblock in using OpenCL on Intel FPGAs. I, for one, have forwarded this very same feedback directly to Intel engineers at least twice, and they claimed other people have also requested this. However, they neither had a solution to this problem back then, nor does any solution that I am aware of exist now. Apparently it is possible to perform modelsim-based simulations if you use the HLS compiler (I haven’t tested it personally), though just for the module you describe using HLS and not the whole system. For OpenCL, considering the fact that it is next to impossible to simulate signals related to PCI-E and DDR memory with any reasonable accuracy, I doubt any proper performance estimation solution will ever be made.
