RicardoC
2 years agoCXL IP for Device Type3 (feature 6AF7 0188) license fails to generate sof
A newly generated license file doesn't allow a previously successful database build to produce an sof file. The license manager log file states the required feature was successfully checked out, and ...
Zane-Jiang
1 year agoHi
I encountered the same problem and haven't been able to resolve it for a long time. Could you please tell me how you solved this issue previously?
Thank you,
Warning(115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores. Warning(115005): Unlicensed IP: "CXL IP for Device Type3 with DDR4 based MemBuffer (6AF7 0188)" Warning(115004): Unlicensed encrypted design file: "/home/jz/NeoProf_FPGA/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/auto_fab_0/22.3.0/final/1/netlist.model" Warning(115004): Unlicensed encrypted design file: "/home/jz/NeoProf_FPGA/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/auto_fab_0/22.3.0/final/1/names.model" Warning(115004): Unlicensed encrypted design file: "/home/jz/NeoProf_FPGA/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/root_partition/22.3.0/final/1/netlist.model" Warning(115004): Unlicensed encrypted design file: "/home/jz/NeoProf_FPGA/hardware_test_design/qdb/_compiler/cxltyp3_memexp_ddr4_top/root_partition/22.3.0/final/1/names.model"
