9 years agoCustom Platform CycloneV
Cheers, Currently I am working with Intel openCL sdk for cyclone V. I completed the getting started guide and now I am researching more in deep about the quartus project created in bin folder f...
9 years agoA. Custom platform BSP, means you can have your-own platform for OpenCL. You can integrate some IO interfaces, or other FPGA IP(s) into system.
B. After .aocx is created , you need to run command 'aocl program /dev/acl0 this.aocx' to configure FPGA , then in host application, it need to get this.aocx content for OpenCL standard procedure to create kernel to run. C. For your project you may need: 1) Custom you BSP, modify iface\acl_iface_system.qsys & system.qsys, board_spec.xml... 2) Write OpenCL kernel code. 3) Write host application (Linux application)
