Custom Library Unavailable in ModelSim after creating project
- 5 years ago
Thanks for your help, ShyanYewT_Intel. I got my ModelSim project to compile following your suggestions, though not exactly. The steps:
1. Started ModelSim from command line from my Linux installation directory (../modelsim_ase/linuxaloem).
2. Created new library "cbgb" and mapping to it.
3. Compiled files into "cbgb" from personal repository directory (../libraries/cbgb/..). "cbgb" appears in Library window with all its compiled files.
4. Created new project "pert" in personal project directory (../projects/../modelsim). Copied settings from (../modelsim_ase/linuxaloem/modelsim.ini) since there was no modelsim.ini in my project directory. This file is different from the read-only master modelsim.ini found in (../modelsim_ase). It got created sometime during the previous steps. "cbgb" library changes to empty "cbgb (unavailable)" in Library window.
5. Added files to project directory (../project/../modelsim/pert).
6. Edited "cbgb (unavailable)" library's Pathname to point to existing library (../modelsim_ase/linuxaloem/cbgb). "cbgb" library appears in Library window with all its compiled files.
7. Compiled my project.
As you create a new project, when a window pop up, you will see a section calls "Copy Setting from".
By default, the Modelsim will direct to the modelsim.ini from the installation directory.
<install_dir>/modelsim_ae/modelsim.ini
Try to change it by browsing to the modelsim.ini in your project directory. See if the cbgb library still available.
If the above does not work, in your current project, you could try to add new library, mapping back to the existing cbgb library.
I hope it helps.
- RichardT_altera5 years ago
I am glad the issue has been resolved. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
