antoineb
3 years agoCustom IP compilation
I am working on a project using homemade IP instantiated in a PlateformDesigner module.
When I try to run compilation, I need to run it 2 or 3 times to succeed.
When compiling for the...
sstrell
3 years agoI'm not seeing the warnings you are seeing. All I see is a compilation error because your exported pio interface is 8 bits wide in the system but you instantiated it in top_ipbus_lpsc_extphy as 32 bits wide.
