antoineb
3 years agoCustom IP compilation
I am working on a project using homemade IP instantiated in a PlateformDesigner module.
When I try to run compilation, I need to run it 2 or 3 times to succeed.
When compiling for the...
sstrell
3 years agoI'm assuming you used the Component Editor in Platform Designer to create your custom component.
Something must be incorrect on the Signals & Interfaces tab of the Component Editor. Can you show that? Is your system able to generate manually in Platform Designer? Are there any warning messages in Platform Designer that might provide more info?
