8 years agoCustom Instruction accessing SDRAM
Hello
I am currently trying to update a memory location content inside SDRAM from a custom instruction(function called from nios ii). From what I understand, I need to use avalon memory mapped interfaces. tried the following implementation below, but would not get it to work. is there something that I missed out or misinterpreted? inside QSYS the custom instruction having a MM master connected to SDRAM MM slave, and for the custom instruction side, a template for avalon mm simple master is being added with a portion of the codes included for custom instruction.
//avalon MM Master port
input clock, reset;
output reg avalon_master_address;
output avalon_master_byteenable;
output reg avalon_master_read;
input avalon_master_readdata;
input avalon_master_response;
input avalon_master_waitrequest; //not used
output reg avalon_master_write;
output reg avalon_master_writedata;
assign avalon_master_byteenable = 4'b1111;
always@(posedge clk)
begin
if(clk_en)
begin
if(start)
begin
case(n)
2 : begin
avalon_master_address <= addressA;
avalon_master_writedata <= dataB;
avalon_master_read <= 1'b0;
avalon_master_write <= 1'b1;
if(avalon_master_response == 2'b00)
n2_done <= 1'b1;
end
end
end
end
end
Thanks in advance2 Replies
Why do you need a custom instruction for this? And the code you post is not complete. It's not clear what n and n2_done are.
If you are trying to implement a state machine, I suggest following the state machine template. - Altera_Forum
Plus, this is not how you construct a Nios custom instruction. There are certain ports you need to use (not standard Avalon) and you connect it to the Nios's custom instruction master interface. See this online training:
https://www.altera.com/support/training/course/oniicus.html
